Jeannot
I bought a puncture repair kit from Ebay. It came with some instructions (see below), I never used a repair kit myself and want to learn on how to use it properly just in case
I can't see how you would use the "gaiters" in case of a puncture. Does anyone has the same type of kit or know where I can find, ideally, an illustrated guide. Thanks
JC
PS: Instructions from seller
Instructions for tyre repair
Locate hole in tyre
Clear area around hole and use reamer to clear hole of nails or debris
(For off road repairs without removing the tyre, use cords)
Put small amount of adhesive on needle.
Push thought hole and pull out. Thread needle with cord. Push through puncture hole – twist and partly pull out leaving cord in puncture hole. Use blade to cut cord from needle.
Repeat process until hole is sealed.
.I can't see how you would use the "gaiters" in case of a puncture. Does anyone has the same type of kit or know where I can find, ideally, an illustrated guide. Thanks
JC
Locate hole in tyre
