Andy Hird
Hi
I'm interesetd in powering a Navigo sat nav which has a mini usb connector and requires a 5V input. Can any body tell me if the Q-Power Lite 03 will do the job ?
If so, can you tell me how I connect it ? I'm guessing I could either:- fit terminals to the bare wires and connect these directly to the bikes battery terminals.... Or connect the negative to the neg battery terminal and the live tap into a switched live so power goes on and off with the ignition ??
Can you tell me what switched live I could use on a 2006 R1200GS Adventure ?
Hope you can help.
Andy
Hope you can help.
Andy
its the last pin which the manufacturer may use for product or data ID , which means only certain or specific devices may work that it recognises. Not sure if this tales out of school ?
