Q~Power Lite series
RAM-man
depleted member !
Wes' Lundernshire
Users of QPAC for the Quest and of the few Q~Power test kits shall be familiar with the product and its concept, which has been further adapted to suit more devices.
Q~Power Lite is a rugged, waterproof charger cable for a wide range of GPS units and uses a convenient right angled mini USB connector, which is compatible with the following devices:
Garmin Nuvi 200, 200W, 205, 205W, 250, 250W, 255, 255W, 260, 260W, 270, 300, 310, 350, 360, 370, 500, 510, 550, 610, 600, 650, 660, 670, 680, 710, 750, 760, 770, 780.
Garmin Colorado models 300, 400t, 400i, 400c
Garmin Etrex color models Legend C, Cx, HCx / Venture Cx / Vista C, Cx, HCx / Summit HC
TomTom One (V2 and V3 only), One XL (V2 and V3 only), GO 520, 720, 920, 530, 730, 930.
Q-Power Lite 03
This power input cable terminate in bare wires, including a splash proof fuse holder. Cable length from power conversion box to bare ends is 0.50 metre, and 1.70 metre to the miniUSB plug. This cable is intended to be installed permanently on the motorcycle. Ideally the waterproof rugged power conversion box is located under the seat and houses the elctronics (a pcb and Vreg chipset rated at 125 deg C) . The cable is run to the handlebar area to provide power to the device.
Q-Power Lite 01
This power input cable terminates in bare wires and includes a splash proof fuse holder. Cable length from cradle to bare ends is 1.80 metre. The Electronics are housed in a special waterproof box that fits in the back of the RAM mount and cradle, so is sandwiched between the cradle and the ball base.
Q~Power Lite series is ideal as a charging or powering solution for various demanding environments and the rigours of modern adventure biking. It uses a high temperature Vreg chipset, rated at 125 deg C (which is higher than typical car chargers, that often find their way to being used)
These can be found on
http://www.gpsw.co.uk/details/prod4145.html
http://www.gpsw.co.uk/details/prod4142.html
Q~Power lite 2 will be availble with BMW plug fitted as an option.
CLC04B BMW Motorcycle Mini USB Charger Cable
CLC04B plugs into the BMW motorcycle power socket and provides external power to your GPS receiver. It has regulated power supply inside the lighter plug reduces the vehicle voltage (5V, 2amp) to the level specified for the GPS.
Compatible with:
Garmin Nuvi 200, 200W, 205, 205W, 215, 250, 250W, 255, 255T, 255W, 255WT, 260, 260W, 265, 265T, 265WT, 270, 275T, 300, 310, 350, 360, 500, 510, 550, 610, 370, 600, 650, 660, 670, 680, 710, 750, 755T, 760, 765, 765T, 770,775T, 780.
Garmin Oregon models 300, 400t, 400i, 400c
Many other GPS and PDA using miniUSB connectors.
Not compatible with mobile phones.
CLC04B-short cable option
CLC04B plugs into the BMW motorcycle power socket and provides external power to your GPS receiver. It has regulated power supply inside the lighter plug reduces the vehicle voltage (5V, 2amp) to the level specified for the GPS. Cable length 1.7m
There shall be a short cable length (0.5m) version of the CLC04B series coming along soon for F800GS models or any GS that has a power socket close to the device or on the beak.
