Quad lock onto BMW GPS bar
Barnoe
Milnrow, Rochdale
BMW GS 1200
I am after a Quadlock connector that will fit alongside or over my Nav6 on the same smaller diameter bar.
i currently have in installed on the handlebars but find it too low and have to look down and also the phone keeps changing orientation from landscape to portrait if that makes sense.
If it was higher next the sat nav it would be perfect, but i cant seem to find a mount for the job.
Has anyone managed this?
Ultimate add ons do some narrow diameter bar stuff Its 12mm dia if i recall
i have the ram ball mount next to my BMV nav cradle
Quadlock mirror mount should do the trick, BUT it will be awkward to mount alongside a Nav 6 because of the twist to lock action you have to do. On my last GSA, I did it, but use a RAM Ball from Quadlock, a short Ram Mount and a RAM mirror mount and all was well, easy then to have the Nav and the phone on a quadLock mount together.
Had a NavVI and iPhone 13 ProMax on there quite easily. Just slide the Nav to the left or the right depending on which you prefer.
You can also gain another 15-20mm by slightly filing the rear of the Nav bracket to allow it to move into the curve.
Have you actually looked at the Quadlock website?
They do the exact thing you're asking for.
I did look nothing to fit a narrow bar, where?
link please 👍
Are you talking about the Scooter mirror mount?
would i be able to attach a extension arm to that?
