Questions for those running centech fuse boxes
Steve_R
West Sussex, UK
Hi all,
I'm on the process of installing a centech fuse box to my GSA
When I've done similar jobs on cars in the past I've always earthed locally to the device I'm powering.
Is this an accepted practice on bikes or is it considered a better practice to run the negative back to the bus in the centech fuse box?
Also......I'm planning to use the autoswitch AS7 to switch a relay for my led lights. I am intending to mount the relay and the AS7 in the big space under my tank where the ABS used to live. Any reason why this might be a bad idea??
Steve
if memory serves there is both earth and +battery wiring that used to serve the now removed abs unit.
i mounted my aux fuse box vertically on an alloy plate,and returned all of the earth wiring back to that ,bolting the old abs earth to it as well IYSWIM
Just the answer I was looking for.
I didn't realise there were positive and earth feeds left over from the ABS (Was removed before the bike came into my possession), I will have a hunt for them over the weekend.
Thanks for your input.
Steve
