Oh, that would be good.Aye, do tell. I might pull mine apart as well.
Have stripped mine down myself , not hard to do.
The tripmeter will probably stopped working because the drive pin has seized into the plastic surround it is held in.
If it has stopped completely the surround has probably snapped off the main body.
I'm trying to figure out the best way to sort out a replacement part.
I got the photos of the a web site hope this helps. I will try and find the site for you it gives good instructionsValker,
Excellent pics - Thank you.
so,
am i reading this correctly;
once you remove the bezel / glass surround / 'top' - all is revealed?
Goolge this. (R100 gs Odometer adjustment) g lots of text and instructions. let me know how you get on, thinking of having a go at mine sometime next yearValker,
so,
Goolge this. (R100 gs Odometer adjustment) lots of text and instructions. let me know how you get on, thinking of having a go at mine sometime next year
Joe
If you can't sort it, get in touch with Terry Vrla in Portland, Oregon. He's on ADV Rider as 'Wirespokes'. He does an excellent repair service, not the quickest but well worth it.
I've just had my GSPD Speedo done, excellent, now accurate and steady, $100 plus postage.
For a G/S and early paralevers Speedhut do a couple of speedos which will replace the original, they are electronic, but with or without GPS and you design your own facia.
What size would be correct for the R80g/s Mr Arkwright?
