R100GS Oil filter change?
Martin.
Birmingham
I`m in process of changing my filter. Now, I could look in the manual, but I`m at work.
All I`d like to know is....Which gaskets/grommets/seals do I need?
There`s a shaped gasket for the cover, a white O section seal, a black square section seal and what appears to be a tubular rubber spacer. The replacement filter from Motorparts did`nt have any new gaskets with it.
You need to be very careful, if you get it wrong your engine will be fubar
You shouldn't need a gasket for the outer cover, just an O ring.
Get yourself a cup of coffee and have a read of Anton largiadiers excellent writeup http://largiader.com/tech/filters/
Ah! Thanks. I was a bit concerned, so after 4 miles home, very steadily, I`ve not used it since. Thanks for the link!
