no idea chris - i have the same bike as you and dont have any such issue - would it be possible that the electrical cables or fuel lines were not fully seated, or that the adapters were not correctly assembled? failing that I would suggest getting in touch with keith directly to see if he has any ideas. If you want, you could send your injectors to me to try in mine, which would rule out either of them being faulty.
do you have any other fuelling or ignition timing mods?
just a thought but the contacts on my injector electrical connector were a bit corroded. it could be possible that your original injectors connectors and the wire had enough contact area to work in spite of any corrosion, whereas the new injectors may not. clutching at straws i know but worth cleaning everything up there if you havnt already.
cheers
gordon
cheers
gordon
