R1100 O-ring for Air-bypass screw. Part number?
Two wheels good
Bobbing up in Cork, IRL
Hi
I need new O-rings for the air-bypass screws on a 1996 R1100
Can anyone tell me the OEM part number - the main-dealer's parts fiche doesn't show an o-ring and they are unable to order it.
Otherwise I'll have to try my luck with a local motor factors.
David
PS I have consulted the catalogues of the usual independent parts suppliers.
If you are talking about item 18 in this diagram...
....then there is no o-ring listed for it. Are you sure the o-rings are original and haven't been added by a previous owner?
Or maybe the o-ring is supplied with the screw itself? If that's the case you'd probably be better going to your local motor factor or buying a bag of assorted o-rings and finding one that matches.
Similar threads
