R1100GS-Front Indicator Removal?
JohnnyBoxer
North Yorkshire
Hi
Can anyone post the page from the workshop manual or explain, please - before I have a look tonight
Cheers:thumb
A pigeon attacked one of mine in a kamikazi attack a while back and I ended up having to take all the headlight assembly apart to sort it out but perhaps I missed the obvious easy method....
Its one of those jobs Johnny, just start taking it apart till you come across the bolts, I think its screen, then headlight etc. Sounds worse than it is. Under an hour with time for a slurp half way through.
Care to share the need for replacement :augie
Remove screen, the headlight, and then under the headlight you got an alu part bolted with 3 bolts, one in the middle of it and 2 located at the same position as the headlight bolts. Then you can see the indicator bolts.
Sounds a right pisser for a start
Noddy..............to remove a scratched one, cause by the dozy previous owner
Can you seperate the plastic black indicator body from the stalk or not??
Indicators
Get an 1150, takes five mins!.
dave gs.
