R1100GS question about brake disk replacement
Gecko
Comin' home
I've got the new disks, the old ones are off and am getting ready to replace with the new ones but is it necessary to replace the wave washer (image 3) BMW part nr 34112314888 and mount bobbin (image 4) (also referred to as the roll pin) BMW part nr 34112314887 ?
The M8 mounting bolts (image 2) look good and I've cleaned off the old araldite so was planning to reuse them anyway but what about these other components? Anyone know for sure what the official advice is?
Also , in the image the wave washer is in a different position to as they came off the bike just now. On mine the washer was up against the brake disk not in between the bolt head and the bobbin. Which is correct?
Thanks guys. :thumby:
I replace discs on 1100rt about 4 months back used old bobbins and washers. It's depends on wear and more on bobbins then washers
