Few months ago I bought a s/h factory rear shock to replace the knackered corroded one on at the minute, and just now getting round to fitting. Couldnt currently afford £££ for a new improved aftermarket unit.
I would like to check the oil level and if necessary, top up. Is it just a case of fully unscrewing the adjuster knob on the remote reservoir, removing the allen head bolt and topping up? If so, what kind of hydraulic oil should be used and to what level? Assuming brake fluid or jack oil would work.
The knob on the old shock currently on the bike seems to do very little at all, regardless of how far in or out it is. It certainly doesnt visibly alter seat height and feels much the same to ride.
In operation, I would think that winding it all the way down so its at the 'high' preload end of the adjustment, should stiffen things up (for fully loaded/pillion) while less preload is needed for single rider. Preload adjustment is a new thing to me...
Gordon
Gordon
