For Sale R1150 GSA
GADGET
Norwich
I did post this up for sale back in August, not much different, other than number plate not available, and reducing price to £5000.
If you didn’t see this before this is MikeO’s old bike and links below with more info
Will add a link to Mikes original post below, only real difference is that it now has a MOT and has been serviced by me, ALL fluids & filters (oil & air), end float, valve clearance and balanced using a harmonizer, also there was an MOT advisory for bevel to swing arm bearings sideways movement, which I tried to adjust the movement out, but on removing the taper bearings they has partially disintegrated, so I invested in the bearing upgrade kit that Motorworks do, which are a bronze bearing surface and come with 2 detachable grease nipples for occasional lubrication. I also had a slight leak from the right side spark plug rubber valve cover gasket, so I replaced all 4 valve cover gaskets.
Recently back from a 1000 miles ride around Wales and the West Country and the bike is running well, debating about selling at all, but I'm away until end October and I dont do Winter riding and have too many bike (5), but if it doesn't sell then thats okay too.
Looks like Mikes pictures have gone too, so will attach the only 2 I have at the moment on my iPad, I’m currently in a very warm Seville and will sort out a better ad when I get back
Im in Spain until next week, so cannot give you an exact number, but had just over 33k when it was MOT'd in July and afterwards had a trip to Wales & Plymouth, so I'm guessing around 34k ish John.
Price reduction on this to £4500.
Trying to clear some space in my garage!
