R1150gs wheel valve leak and warm grips
[email protected]
North Wales
Hello, a few issues I have with my 2004 r1150gs adventure, I am losing pressure on the front tyre, I believe it is coming from the valve which was replaced when new tyre was fitted 10 months ago. Is there a specific valve that should be fitted to these Rims? As the one that came out wasn't the same as the one now, and I had them changed in a local garage.
Secondly, I replaced my worn grips with r1100gs ones with vertical ribs. But they are too thick so only allow limited heat through, can anyone send me a link to better grips fit for purpose that will fit over the heating elements. Many thanks in advance, Ashley
Have you checked the valve core isnt loose? Is it definitely the valve?
Sent from my SM-G986B using Tapatalk
