Bury_Dave
More stupid questions from me showing just how little i really know about bikes still.
First ....... I was out on the bike Sunday. Started no problem. Then, whilst fitting Nippy Norman's footpeg lowering kit, i left the ignition on for a few minutes to try to sort the adjustment of the brake pedal (more of that in a minute). Then when i came to start the bike to head out for a test ride, not enough juice to turn the motor over.
Now i have a trickle charger I bought last winter but never ended up using. It's supposed to be an 'intelligent' charger. Sadly it's only as intelligent as the muppet who wants to use it. Me !
So, to use it, can i plug it into the battery whilst the battery is on the bike and wired up (only having to lift the tank a little) or do i have to remove the tank to remove the connections and then connect the charger to the battery ?
Second ...... after fitting the footpeg lowering kit and adjusting teh gear shifter no problems, I thought i had lowered the brake pedal ok too. But when i turned the ignition on, the brake warning light was on and flashing. I tried adjusting the pedal this way and that but couldn't get the light/beeper to go off. That's what drained the battery.
Any help to educate me would be most gratefully received
Dave
Dave
