R1200C Steering Stem Stripped Threads.
  • Thread starter Thread starter Setzer
Setzer
My Father in Law recently came into possession of a R1200C,he has been giving the bike the "once over" to make sure everything is just right.
Today he has come across a bit of a problem,the threads in the steering stem are stripped (the threads that are in the frame itself).
Would anyone know how he would go about getting this fixed.
Thanks in advance.
threads
If you are referring to the threads on either side of the shock mount? they can be drilled out and rethreaded to the next size up or you can use an insert and stick to the original size. Either way both are pretty easy to do yourself, with a bit of mech experience.
cheers,
Paddy
contact the nearest BM dealer ASAP with the frame number
There was a recall for this fault
I did a couple of them it was basically a big thread insert is used in the
headstock for the top ball joint and If I remember correctly Hurts have the required kit that was
involved in the campaign
If you don't get satisfaction from Hurts at Mallusk re the warranty aspect then you need to contact BMW
directly at customer services, Be Nice and Be pleaseant but firm and don't threaten
Just ring up and ask what to do now? The Girls get threats of legal stuff everyday
Since it's warranty any European dealer can do it, so perhaps one of the establishments down south as I believe Hurts are having Staffing issues in the workshops and are backlogged?
1200c steering head
Is this the recall? From Chromeheads Forum
NHTSA CAMPAIGN ID Number: 01V217000
Component: STRUCTURE:FRAME:MEMBERS AND BODY
Manufacturer: BAYERISCHE MOTOREN WERKE
Year: 1998
Make: BMW
Model: R1200C
Recall Date: 07/02/2001
Type of Report: Vehicle
Potential Number of Units Affected: 3342
Manufactured: 06/1997 - 06/1998
Defect Summary:
VEHICLE DESCRIPTION: MOTORCYCLES EQUIPPED WITH CHROME-PLATED FRAMES. COPPER RESIDUE CAN REMAIN IN THE TAPPED HOLE WHERE THE UPPER FORK BRIDGE ATTACHES TO THE FRAME. MOISTURE CAN CAUSE CORROSION TO OCCUR BETWEEN THE COPPER RESIDUE AND THE ALUMINUM FRAME. THE STRESS OF THE CONNECTING BOLT ATTACHING THE UPPER FORK TO THE FRAME COULD THEN DECREASE, LEADING TO LOOSENING, AND ULTIMATELY, BREAKAGE OF THE BOLT.
Consequence Summary:
IF THIS HAPPENED, THE DYNAMIC STABILITY OF THE MOTORCYCLE WOULD BE AFFECTED AND A LOSS OF CONTROL COULD OCCUR.
Corrective Summary:
DEALERS WILL REAM THE HOLE IN THE FRAME HEAD AND INSTALL A HELICOIL THREAD INSERT AND A NEW BOLT. OWNER NOTIFICATION BEGAN DECEMBER 13, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT BMW AT 1-800-831-1117, OPTION #4.
Is this the recall?
Michele
Moderator
Posted on Thursday, September 08, 2005 - 6:25 pm:
Pokie has very kindly offered us a link his technical article on this topic. He was comfortable fixing this on his own bike.
click for Pokie's tale
Please remember that a recall is a "must fix" item, no matter what your bike's warranty status or if you aren't the original purchaser; the BMW dealer must fix it at no cost to you, if your bike hasn't been fixed.
Thats fantastic news!
Thanks very much for the info it is really appreciated,I had absolute faith in this forum :thumb2
When I find out what BMW are going to do about this I will let you know.
Dave.............
