R1200GS 2018 LC fork seal
MikeW
Wirral
Hi all 👋
My Right fork seal is blown going to replace seals on both legs.
I’ve searched but struggling to find capacity and weight of oil 🤔
can anybody inform me please. 🙏
thanks
Mike W
The haynes manual says 485ml of 10w and an oil level of 135mm.
Its not really that critical, there is no damping cartridge in the fork.
Stu
Hi all 👋
I thought I had a blown seal on the right hand fork leg of my old 06 GSA
It turned out to be a bit of crap between the seal & stanchion which I removed by slipping a feeler gauge between the two :thumby:
Thanks for reply but have tried this with no luck 😬
Stu
Cheers stu I realise there’s no damping as such I just want to get the job right.
I've got the factory manual on DVD that they will no longer sell to customers.
It says: Capacity approx. 485 ml
Fork oil fill level measured from the top edge 135 mm +/- 2mm
Telescopic fork oil "Telescopic fork oil type1" BMW p/n 31 42 9 062 158
You might check with a BMW parts store to see if you can find out more about the fork oil. I agree with poster MS30SJM - it probably doesn/t matter what weight fork oil you use as these forks don't do any damping, just sliding up and down.
Hi all
thanks
Mike W
Or ... Depending on the miles that the bike has done, get the whole thing serviced by denz0 on here.
Sent from my Pixel 6 Pro using Tapatalk
