R1200gs with Givi extended screen - Need some suport please
Santa-2512
Omnipotent one
North Pole
My GS came with a Givi extended screen,
However it rattles and vibrates like a demented conga dancer on tickover.
Looking at the screen, there are two holes near the top outer portions of the screen, which do ???
from what i can gather there is some form of bracket that goes from there to a point on the
instrument binnacle?
I contacted Givi, who sent me the fitting instructions to the the extended portion of the screen,
not the lower portion .
They have now come back to me and have asked if i can provide pictures of this fixing bracket /
arrangement, so they can go back to the Givi engineers to see if they can identify it so they can see
if its available as a replacement part.
S oif you have the above, can you post pics please
regs
Mart
The holes are probably for the upper screen mount on the GSA.
There's bound to be a couple knocking about if you put an ad in the wanted section.
Is it the Givi 330 adjustable screen with the top part that slides up and down and is it the lower screen that has the two holes?
If you Google 'Givi 330' you'll find pics of it.
If it is the 330, you may be in luck. I have a pair of the lower screen support brackets that you are welcome to have. I had one but never could get on with it. The bike fell over at a junction with a step camber and the screen was a write off. Kept the brackets.
Thanks for that John,
i think the pic shows the screen & bracket were discussing
<a href="http://s16.photobucket.com/user/mart360/media/Givi_AF330_BMW_R1200GS_Airflow_Vetro_WindShield-2_3.jpg.html" target="_blank"><img src="http://i16.photobucket.com/albums/b30/mart360/Givi_AF330_BMW_R1200GS_Airflow_Vetro_WindShield-2_3.jpg" border="0" alt=" photo Givi_AF330_BMW_R1200GS_Airflow_Vetro_WindShield-2_3.jpg"/></a>
Mart
That's them. The 'C' shaped ones. No wonder it's wobbling!
Message me your address and I'll send you them for the cost of the postage. You can have a spare upper screen as well if it's any use to you.
The C-shaped struts also have thick washers that fit against the OEM screen height adjusters. You can do the same job with normal M8 washers (M6 are too small) I lost my Givi washers so have three M8 on each side. If you have an adventure the Givi does not use the OEM screen brace. This causes the OEM adjusters to damage their alignment fingers. Mine were already chewed so I cut them short. You might want to get some GS adjusters which have shorter fingers.
