Mine has started to slip after 2000 mile (will be returning under warranty) is this a common problem, what’s the repair or should I be asking for an upgrade, info gratefully received
Make sure your Hand guard is not stopping full travel on the clutch lever before you take it into the dealer, mine was slipping and moved the guard and its been fine for the last 12000 mile
Big problem is if your clutch was slipping because of the hand guard
had it been incorrectly fitted by the agents or by you
the clutch is worn and the life reduced
how long will it last ! ! !
take it back ask for it to be inspected under warrenty
