Hello ! i have a gs 1250 2023 model and while i perfomed the first detail clean i noticed that the rear suspension dust cover ( plastic tube ) which is inside the spring is rubbing with the spring on the inner side and leaves a tiny mark . although i tried to clean it as i push it it has a bit of play and you can hear a bit of click as you push it back and forth for a tiny bit ( maybe 1-3 mm ) ? also it spins - rotating on itself but doesnt go up nor down . Is this normal ?
