R1250GS Bungee points
hawkeye
Billericay
There have been a couple of times in the past when I've needed a couple of bungee points on my R1250GS - finally cracked it with a couple of Wunderlich tie-down loops from Nippy Normans. These nicely bolt on using the fixing points for the rear rack, all I did was replace the standard screws with some 30mm long ones and a couple of lock nuts and job done. Quite discrete as well IMO.
Thanks for that. They’ll be handy.
I’d guess they would also fit on the screw below. The 4 points holding the cover on under the back seat.
They would if the fittings were drilled out (the fittings have 6mm holes and the holes holding the cover on are a larger size 8mm or more), but I didn't want to interfere with the fittings for my Vario panniers.
Thank you for this post, very helpful I never thought about this.I just ordered some.
sorry to be a pain , what is the crew size M5 or M6?
