For Sale R1250GS / R1200GS cast alloy wheels.
richh
Leeds.
Bought these and had them powder coated gloss black.
Are now surplus to requirements as gone with another set.
They have just been powder coated last week by LSN in Castleford.
I have carefully unmasked the disc mounting / tone ring mounts / tyre vale area.
They are real nice. Excuse any dust and greasy fingerprints in the pics. They are as nice a pair of wheels as you will find without buying new. IMG_6780.jpeg
There are some slight pitting marks on the rear wheel where they had corroded under the factory coating. They were dipped / stripped before the new coating applied, so the coating is sound. But you can slightly see / feel where the pitting occurred. It's mainly on the drive shaft / inside, so not really visible once fitted.
There is a little blemish on one side on the front, where the bearings go. With think this could have been a little "out gassing" of the alloy when it was heated for the coating. It's almost totally covered by the seal so hardly visible. Again just want to be totally transparent. See last pic for this.
I'll include the tone ring and fixings. And the screw in vales. You'll need your own TPMS sensors of course.
£500 the pair.
This pic shows the slightly rougher texture to the powder coat in the area that was corroded.
Also included is the bearing spacer. But you’ll need a new bearing kit.
