R1250GSA Timing Cover Protection
Sparklyman
South West
Hi all,
Considering a few items of protection, to limit corrosion or damage to potentially expensive parts.
Seems a front fender extender can help mitigate issues with the Timing cover, together with a Mudsling (or chinese copy) to look after the rear shock.
Is a timing cover protector a wise investment for road use ? (Unlikely to do much off-road initially ...)
Have seen Alloy items from EP, Wunderlich, plus an ABS cover from China ...
Any comments or suggestions, based on experience ?
Many Thanks
Take the plastic cover off ,remove the sponge inside ,spray with Dinatrol Heat proof wax .
Replace the cover let wax cure and remove any excess. :thumb2
I think you're possibly referring to a Hexhead or earlier bike?
Just to help you get your bearings (pun intended)
I think you’re talking about the front engine cover which houses the clutch and water pump?
The only major difference between the 1200 & the 1250 is the shift cam gubbins on the end of the intake cams
Yes - thanks for that
Found my first parts explosion for the Boxer yesterday and realised it's not a timing cover
The clutch/pump cover looks very vunerable to stone damage - I think protection is a must - very interesting to see what others recommend ..
I’m glad someone else has advocated our own cymarc for this.
The man is an inmate here, loves his bikes, and makes very fine products at a reasonable price.
He doesn’t seem to be making much money from the parts he makes, unlike the Touratech/wonderlich…etc etc.
….and if he doesn’t alread6 make something, contact him via here, and he will design something.
DC
Thanks for the links guys - I'll investigate further today ....
I avoid Chinese copies if at all possible - quality of materials has always been an issue, especially when it comes to fasteners.
However, some of the bigger names don't seem to have great value for money - overly priced plastic mouldings for example.
Maybe Cymarc is operating in that middle ground ?
Thanks for your help ....
Hi
I opted for the Wunderlich Injection Moulded guard - relatively large, covers the majority of the cover and wont corrode if it does get hammered by stones etc.
Expensive at £89 - the quality is there, but it still doesn't smack of value for money - I guess Brexit is now showing an influence on "foreign" parts !
Only thing I didn't like was torqueing the lower bolts to the stated 10 Nm. At 8Nm the uppers and lowers were fine. At 10Nm, the uppers cinched up nicely with a few more degrees of rotation, but the lowers continued to rotate much further ....so I bailed out, knowing they'd reached 8 Nm - just didn't have confidence rotating them any further.....this with a calibrated torque wrench.
Wondering if anybody else had a similar experience with this Wunderlich Plastic Cover ?
