Have been overcome by a sudden burst of enthusiasm to get my R80/7 back on the road (must be winter in the air).
Anyway, here's the story/rough plan...
The bike cooked a big end about a year ago (main bearing retaining pin fell out and the bearing rotated in its housing, cutting off oil flow); since then not a lot has happened apart from getting a complete bottom end rebuild (new mains/big ends, used/good nick RS crank & crank reshimmed) by that nice man Steve Scriminger.
Unambitiously, I'm not going after extra performance or more suspension travel, as I'm quite happy with the bike as general runaround. But I am going to try to lose about 10-20 kilos off it as well as coolify it a bit, hopefully without losing too much of its practicality.
I’m also keeping all the old bits so the it will all be completely reversible if the cosmetic surgery all turns out a bit Pete Burns. So far that has only meant picking up an old subframe as a spare (a hacksaw has already been taken to the original part – see below).
The broadly intended look is 70s Brit bike scrambler, so I’m looking at wirespoke wheels with TKC80s, shortened alloy mudguards and single (police) seat on a shortened and raised rear subframe. The bars are cheapo XT500 replica. The pic below shows roughly how some of these bits will probably fit together. I haven’t come to a conclusion about the exhausts yet.
I already have a wirespoke rear wheel but still need a wirespoke front of the type that goes with ATE calipers, if anyone has one they want to flog…
When I get the subframe welded up in its new position, I’m also going to get a small rack fabricated at the same time which will fit in the space between the seat and the rear light (cheapo small Lucas replica with custom mounting bracket I made out of 2mm mild steel sheet).
I’m also going to do something ingenious with a spare mudflap I have to provide more protection for the battery cage.
I think I’m gonna leave the indicators as they are for now so if anyone has a rear indicator mount, I have cash waiting for one of those too…
It would be good to still to be able to mount the pannier racks, but the subframe mods and most of the exhaust routings I’m thinking about will probably make that a challenge too far…
