England-Kev
When changing the large bevel box seal behind brake shoes, can you change it in situ, or do you need to remove the cover to do it. also apart from the seal and possibly the cover gasket, are there any other parts that need to be ordered also.
I have a leak you see, and I am not sure where from, I am hoping it is the brake cam shaft again, ( I only changed the o-rings last year) so I am going to replace the shaft o-rings, and run it to see if it leaks again. something has let go though, as my rear tyre got covered in oil today, I will post pictures in a while.
