For Sale RAB Aeon 27L Rucksack.
Tony Smith
de-Smiffy
Broadway, North Cotswolds.
This is a used Daypack, but only used once, so it is in great used condition.
It may have small signs of wear with mud or grass, but nothing detrimental.
It is still like new.
What RAB says;
The Rab Aeon 27L Daypack is perfect for day hikes, light overnights, sure-footed scrambles, and fast descents, the Aeon 27 is built to move with you over all terrain. With a range of technical features for all ascents and a close fitting back system that flexes as you move.
Carrying everything you need for mountain days, the Aeon is designed to give you freedom of movement over all terrain. The close-fitting Air Contour X carry system is sturdy enough to carry heavy loads, whilst keeping the weight centred for agility on steep, tricky trails. It’s semi-rigid structure and vacuum formed back panel, moulds to your shape and keeps the air flowing. It has a wrap-around stretch yoke that fits neatly over the back of the shoulders for a soft, secure fit, with an adjustable back length and forward pull hip belt to personalise the fit for all day comfort.
This panel loader pack is refined and streamlined, with a low-profile style optimised for all mountain ascents. At 27L there’s enough space to pack gear for lightweight bivi overnights or bothy stopovers. It has two TipGripper walking pole attachments, a walking axe loop, and easy access, expanding stretch pockets, ideal for stashing wet gear. The zipped hipbelt pockets hold snacks or compass and the rain cover is prepared for all weather. Completed with a robust 70D construction now made with 50% recycled fabric, the Aeon is ideal for clocking miles over rugged ground.
Features
• Secure TipGripper walking pole attachments
• Raincover for complete weather protection
• Adjustable back length for personalised fit
• Forward pull hipbelt for easy adjustment
• Panel loader with zipped entry
• Large stretch mesh front and side pockets, great for easy gear stash
• Top drop pocket
• Internal and external lid zipped pockets for easy access to frequently used items
• Secure internal zipped pocket perfect for valuables
• Vacuum formed, precurved and molded ABS back panel with semi rigid structure, maintains shape of pack whilst flexing with the body
Specifications
• Dimensions:56 x 27 x 23cm
• Volume:27lt / 1650cu.in
• Weight:(M-L) 0.98kg / 2lb 2oz, (L-XL) 1.03kg / 2lb 4oz
• Product Code:QAP-06
• 50% Recycled 70D x 140D Nylon S DOBBY / Trishield
• Zipped hipbelt pockets perfect for snacks, gels or compass
• Light loop
Any questions please ask.
Post to UK postcode only.
Looking fir £75.00 posted.
PayPal F&F.
Tony.
Sent from my SM-A536B using Tapatalk
