Range of Torx sockets
bumpy
Herts
I want to treat myself after Christmas to a range of Torx sockets, so some questions.
1. What are the required sizes for the GS1200. I dont do major engine rebuilds but want to tinker with handlebars etc.
2. Do I need both male and female.
3. I have a 1/2" torque wrench so should I look for 1/2" sockets or will a smaller drive do the job (plus size adaptor).
Will probably go to Halfords unless you know better.
Bumpy, I'd concider buying sockets for the larger sizes but I find it's more convenient to use an allen type torx wrench for the smaller sizes.
I've not found a use for a T27 yet.
You'll need a torque wrench that goes up to 44lbs (60Nm) if you want to remove/replace the rear wheel (on a 1200GS). Buy a T50 for the rear wheel bolts & only buy a T55 if you plan on frame work i.e. fitting crash bars.
Halfords do some decent sockets/keys. :thumb2
I 'aint found any fastener I can't remove yet with....
Allen key set
T50
T45
T40
T30
T27
T25
T20
T15
T10
Sockets
T55
T50
T45
T40
Sockets, female
E8
E10
Still need tips on where to buy, and if its important to consider a torque wrench?
Depends if it's going in the tool-roll or not.
I use a mini-ratchet in there, as it all still manages to fit under the seat that way...
As far as purchasing locations, I just did a mix-n-match purchasing job and bought them all off the Draper website. Probably could have got them cheaper if I'd fought for it, but *shrug*
