For Sale Range Rover Sport (L320) Heavy duty sump guard
Snow White
Middle of Norfolk
Yes, you did read that correctly a proper sump guard for your (late) L320 Range Rover Sport.
This is a genuine Land Rover sump guard for a Discovery 4 that has been professionally modified to fit a Range Rover Sport and gives you access to your front recovery eye.
Because the D4 and late L320 had the same chassis it means all the bolt holes are all there and it will come with the required bolts and clips to be a straight fit. The only thing you need to modify or remove is the little black flaps below the bumper. (I just cut a bit off)
Clearly this is used,
so does has some scrapes, but still fully serviceable.
£250 (+p&p) or collect from NR19 (middle of Norfolk)
