Moto loca Guest Nov 16, 2007 #1 need some info my bike has a rattle noise on front of the engine at 3000 to 5000 rpm 07 40 mile Thank you all
Golddust Guest Nov 16, 2007 #2 My handguard was touching the front brake line and making a terrible noise. Might be worth checking.
Dahoum Registered user Joined Jul 20, 2004 Messages 16,183 Reaction score 2 Location ................ Nov 16, 2007 #3 As someone said over in the newbys section, it is under warranty - get down to your dealers
GSmonkey Well-known member UKGSer Subscriber Joined Nov 22, 2004 Messages 5,645 Reaction score 1 Location Bromley Nov 16, 2007 #4 Most likely the screen in one form or another. I find the simplest solution to be earplugs
Matt splat Guest Nov 16, 2007 #5 Check your panel torx bolts, also your mist lamp bolts if you have them. I developed a rattle, it was my mist lamps!
John Armstrong Well-known member UKGSer Subscriber Joined May 25, 2002 Messages 14,280 Reaction score 253 Location Siorrachd Obar Dheathain Nov 16, 2007 #6 Checked the engine bars? Had a very strange noise on an 1150, the engine bar was cracked, and when I replaced it the noise went away
