Re safety cameras
  • Thread starter Thread starter Joe
Joe
Having problem with the speed camera overlay, the safety cameras is shown in the drop down menu of my mapsoucre, but when I click on to it from the drop down menu the screen is blank???? so I xcan't over lay it noto the maps, any ideas :thumb
The overlays are maps so you need to first select them with your map select tool then go to your normal mapsource and select the normal maps you want to use and send the whole lot to your GPS unit. If you have done it right you should see the names of the countries for the overlays in the map tab on the left - where you see the list of all map sections selected.
Zoom into an area you know there's a camera, select the camera option in the drop down menu, zoom out slowly till you can see it. At some point when you continue to zoom out (10 miles?) you loose the cameras again, DAMW.
Set detail to ‘highest’ then zoom out
