Rear Brake Mount, Change.
Boedkerman
Middelfart, Denmark
1997 1100GS
Need to change the Silver mounting plate for the Rear Brake.
For the life of me, I cannot see how this is possible.
1 mount has a nut covered by a fixed rubber grommet that will rip if the nut is unscrewed (tried on a spare)
2nd does not seem to have any bolt/screw/nut fixing.
Words of wisdom appreciated
Photos greatly appreciated
Mike
When you remove the silver mounting plate from the swing arm (two bolts) the calliper comes with it. The caliper can then be pulled off the plate. Trouble is I’m not sure you can buy the plate separately (try Motorworks or Sherlock’s). The design isn’t great imho.
