REAR BRAKE PEDAL HEIGHT?
  • Thread starter Thread starter ianmac
ianmac
Can you adjust it(up in my case) I cant see any way of doing it, it feels too low at moment .
PS does the ABS work on rear if you just use rear brake, ie will it lock up with enough pressure, I ask because there is no ABS "ring" as on front caliper.:confused:
12GS
GSXR1000K3
H-D ROADKING.
These questions have been asked & answered here before........
1) There is no ABS ring on the rear wheel, but the ABS sensor is aimed at the five spokes of the disc carrier, which is why the rear wheel ABS is much more 'jerky' in use than the front......
2) This photo shows the brake pedal adjustment and that of the brake light switch which will need altering if the pedal is adjusted.....
Dutch
Remember the switch is important - it's not just the brake LIGHT switch, it also controls the servos and if you adjust it wrongly your servos may NOT work. The "brake failure" light on the dash will indicate if this is the case,
Hi
When i removed the rubber inserts in the footrests this was enough to bring the footbrake to a comfortable position
Easy enough to do and you shouldnt need to adjust the switch!
Regards Shep :D
