rear hub/driveshaft
Just change the oil every so often.
Check the paralever bearings for play. If there is any it can be adjusted out, but usually means they're on the way out so best replace.
Don't confuse paralever bearing play for wheel bearing play though.
Lube the splines if and when it's apart.
