Rear Mudguard removal.
GedJack
Lancashire, God's country !!!
Just need to remove the rear mudguard and beak for painting of my 1150bGS
Is the mudguard easy enough to take off ?
Looks simple enough.
Cheers Steve.
Yes, straightforward AFAIR. I think the front of the rear mudguard is only "hooked-on". But you might have to loosen the fuse/relay box mounts.
The two captive nuts on the bolts through the rear rack will be a bit rusty.
The beak is more a chore I'd say . You'll have to open the indicators to disconnect the wires and feed them thru' the stalks.
