Sold Rear Weiser Wizards for 1250GSA
GSite
Nr Sleaford, Lincolnshire, UK
Hi All,
Has anyone got a surplus pair of Weiser Wizards for the rear indicators on the R1250GSA (2023-4 model)
Using the GS911 managed to code out the front running lights and get the rear main light to function as running / brake light.
Hi All,
Oh - nice to know you can do that with a GS911! I put a full set of weiser wizards on, didn't know the GS911 could do that...
Yes, also coded out the rear multi-function indicators so they act purely as an "indicator".
Thought it would be better to have them work as stock but kill the red of the brake / running light when indicating.
So what do you need the Weiser for if you've coded that function out?
In coding out the multi-function indicators with the GS911 there is not the option to set them up to work as per the Wizards.
You are actually reducing the running light and brake light function to 0% rather than cancelling the function out completely.
You cannot set it up to allow additional brake light function to operate and be cancelled while indicatiors are used, hence wanting to use Wizards on the rear only.
Ahh gotcha!
