rear wheel bolts
scoobert
Florida, USA
Quick question, what size socket will I need to take off my rear wheel?
2016 1200GSA
Thank you
T50 will do nicely, assuming no change since 2015. Riders manual may help with this and other stuff.
T50, thank you. Anyone find a fix for water on the back of the right leg when riding in the rain or on a wet road?
Aye, ride your bike on the correct side of the road, then it will be a wet left leg.
Not a worry in Scotland, it never rains.:flag
JimmyMac
Remove the lump of black plastic that's attached to the final drive. Replace it with an extended flap below the license plate.
Thats what causes the water to hit my right leg? Guess I could see it, but really?
On or off makes no difference at all in my experience, a mudsling helps but is by no means a complete cure for the spray.
It was more so on the pre LC models but it holds good to a lesser extent on the LC. I've also fitted a Mudsling to my bike and that's helped a bit as well.
Mudsling & frame infil panels, could have sworn it was rear of my left leg tho..
the touratech infils are very good but if I remember very expensive, I believe Bmw do their own now a LOT better value for ££
