Rear Wheel Removal
Ectopic
England
A quick (and very basic) question, if you don't mind.
I need to remove the rear wheel from my nephew's bike to take it to have a leaky air valve replaced. The BMW Riders Manual isn't particularly clear on whether I need to (a) remove the spray guard or (b) remove the silencer. It seems to suggest both depending on the model, without being very clear. It's a standard R1300Gs, spoked wheels, standard silencer.
Which method do you all prefer?
If dropping the exhaust, the manual seems to suggest that the clamp attaching the silencer to the downpipe is a 'use once only' affair (although, again, it isn't very clear). Is this true?
Thanks in advance...
It will come off with both the spray guard and the silencer still attached the the bike on the centre stand.
The part manual suggests that the exhaust clamp should be replaced if removed. Don't know why though.
I found it impossible to remove the rear wheel without removing the muffler or rear mudguard on the 1250 and 1300 gs. Never replaced the muffler clamp.
I’ve just done it this week . Remove the spray guard . You don’t need to touch the exhaust. Take out the 5 wheel bolts and lift the wheel up a tad as you move it rearwards . 5 minute job
Putting the wheel back on is easy as it locates and rests on the lug.
I’ve not bothered putting the spray guard back on
It depends on the exhaust. With the stock exhaust, you don't need to remove the exhaust.
Personally, I would remove the spray guard as I think it makes it easier and is literally a 30-second job.
I've been doing it for the last few years without removing anything on 1250GS, 1250GSA and 1300GSA. But just thought, on the 1250's It was always with the OEM Akrapovic end can. I apologise if it's not possible with the standard can.
Thanks, all. It has standard (non-Akrapovic) exhaust. I'll remove the spray guard. It might be possible without but it takes two minutes and will make it a bit easier, I'm sure.
(I've removed wheels on GSes hundreds of times, just not done the 1300 before. On my 1250 I remove the silencer because I have a Puig hugger which is a bit tricker to remove. No mention or replacing the exhaust clamp for the 1250. The wheel won't come off without removing either silencer or spray guard/hugger, unless it's on a ramp with removable plate bit.)
It all depends on the tire and the height of the rear off the ground
Even though I didn't need to do it, it would help to put a piece of board of something under the centre stand. It'll just give that bit more clearance.
It was a doddle on the centre stand and removing the spray guard. It was almost too easy, and not worth getting the tools out for.
