Refitting Standard Exhaust
joness7
London
I am removing my BOS full system to put the standard exhaust and headers back on. The dealer fitted it for me at the 6k service and I'm moving it over to my new SE.
I currently have the standard end can and the header pipes in my shed and that is all!! No clamps, bits, screws etc.
So the question is:
1) Were all the clamps etc re-used on my BOS system?
There seems to be one around the joint between headers and slip on link pipe, and another clamp under the centre stand around some bracket attached to the frame.
2) Are these the same mounting points as used on the standard exhaust?
3) Is there any consumables I should buy before I attempt this? Gaskets etc.
Many thanks
Steve J
Steve
All the clamps should be the same. Check the original hanger is there which clamps around the CAT part of the headers.
Get a new set of exhaust gaskets as they are technically a one use item and will probably leak:thumb
