Delboy777
As far as I can remember we Dyno'd one bike - fitted the Accelerator module and did the Dyno test again......... no noticeable change. The ACC module is really just a Resistor with a bit of wiring as far as I remember - this changes the value of the info sent to the ECU, which in change will add more fuel to the mixture. however the ECU is the little shite that then talks to the Lamda sensors, which tell it that the ratios aren't correct and the ECU re-adjusts again to compensate....... so really you go into a loop.
We then tried the ACC module and actually disconnected the Lamda's...... and yes then we noticed a difference and the bike was great for a few rides, but not advisable to do this on a long-term basis. In fact we removed the ACC module and tried it just with Lamda's disconnected... and response was same as with the module connected.
If I was you... do a run for a few miles - carefully disconnect your Lamda's and try the run back again... see if you notice a difference in response...?
Goose i know exactly what the module does ive read up on it on here and elsewhere and the feeling seems to be that it does work for what it was designed for, ie to smooth out the lean running mixture and so make the bike a little more friendly while in slow traffic etc. Im well aware that it will make no difference in power output thats not what it was designed for, but it seems it does do the job for those that have fitted one..
