PanEuropean
Howard wrote:
An external antenna on a SP III would also provide a noticeable improvement, but because the SP III does not process and respond to the satellite signals as quickly as the newer models, you often don't notice the loss of satellite reception.
PanEuropean
PS: The little antenna that Mike O has (see photo right above) is, in my opinion, the best one to get. It's really tiny, but really, really powerful. It also has a built-in magnet on the bottom, in case you want to use it on a car - just plop it on the roof and it will stay there. I used the that exact antenna, with the internal magnet holding it on the aircraft roof (against a steel backing plate) for the last two weeks - it stayed put at speeds up to 300 MPH.
The SP 26xx family uses a different antenna than the SP III. In an effort to make the GPSR smaller and less obtrusive on a car dashboard, Garmin used a flat antenna that is mounted within the case. This antenna is generally as good as the 'stick-up' antenna on the SP III, but when reception conditions are difficult, it's not quite as good. Hence, many of us are adding aux antennas."Why do all these BMW navigator things need a remote aerial? I get a perfectly good signal on my SP3 with the little aerial sticking up behind the windscreen."
PanEuropean
