twincam
the threads are stripped in the body of the rear remote preload adjuster any ideas on a cure or where to obtain replacement would be much appreciated, can I assume that the only negative effect will be that the preload is constantly on its softest setting ? while not ideal this wouldnt be the end of the world as I know it
....if this is a known issue you could try your arm with BWM for a free replacement ..
