Removing and replacing the seat retaining screw for Hp2e
de crowe
west of ireland
I need to remove the seat on my hp2e. Battery woes. the retaining screw is now threaded. I need to remove the retaining screw and replace it.
Any suggestions as how to get the retaining screw off as the one "key" i have for it is now threaded, not getting any bite at all on the screw. I presume the touratech is the best/only replacement.
thanks in advance. here
I've got a Wunderlich replacement on mine, I think I used mole grips to old one out.
best of luck
Get a decent torx bit or key (t-30) to undo it.
Then change for a high quality aircraft spec Zeus fastener
http://www.southco.com/browse/dzus-turn-to-close-turn-to-open-quarter-turn-fasteners-7514.html
go for this style
Cheap option:
£0.04 Can be undone with a coin/screwdriver etc
But whatever you go for, don't forget to use a spring washer if your replacement doesn't have the graphite insert of the original.
