REMOVING CAT FROM ORIGINAL HEADERS
verona
Dorset
I have a 06 1200GSA and want to remove the cat so I was wondering if anyone here has removed the cat from their original headers IE cut them open and removed the innards and if so are there any down sides or reasons why I shouldn't do it this way ? Jay
Or if the price of the Remus headers is a bit steep for you talk to Rong on here. He does a Y piece for around £100. You saw the existing pipe off just in front of the seam where the cat is welded in, insert his Y piece and reconnect the standard silencer. It seems to go a bit better, although I doubt if there's more than a few bhp in it, but it sounds nicer too, and not offensively loud. Also supplied with the kit are two sleeves, which when welded to your original cat, mean that you could bolt that back in if ever they introduced emissions testing for bikes. This would doubtless save you rather a lot of dosh if you had to buy a new cat off BuMW having ripped the innards out of the old one. Oh, and just for good measure, it retains all the advantages of the original pipes, i.e. dimensions, balance pipe and Lambda sensors.
As usual, no connection, just a satisfied customer.
Cat removal
Thanks for the replies . I have also noticed that motor works now do a y piece at £180.00 . MMM what to do .
