Removing Starter Motor Cover
Our Gee
North Yorks
Please can anyone advise how to remove the Starter Motor Cover on my 2007 GS. (just want to check everything is tight and clean). I can only spot one screw at the rear end just above where the Gear Linkage enters the Gearbox. Thanks.
Remove screw, ease cover to the rear to get it off two pins on engine that fit into rubber grommets on the cover. With the cover now free, wiggle it out in forwards direction between the frame tubes.
Fitting is reverse of above.
