Removing the BWM Badge from the Tank........
  • Thread starter Thread starter CoolCarbon
CoolCarbon
Has anyone done it..........if so how's it done?
Without makin a mess of course!! :p
CC
:cool:
mike,
the easy way is a large rock on rudland rigg, north yorks!
guess this wasn't really what you meant...!?:rolleyes:
d:gringo
Read (I’m sure on this board) two different ways;
1. Heat badge with hair dryer/heat gun to soften the glue and carefully prise off.
2. Use dental floss to cut through the glue that the badge is stuck on with.
Have not needed to remove a badge myself.
Good luck.
Corsican Dave said:
mike,
d:gringo
Cheers 'CD' That'll be the same one you used to "Customise" yours with then :D
I was thinking of something a little less dramatic........;) But thanks for your input. I trust all is fine at sunny Braemar-by-the-Sea!
I'll try option two suggested by sandbaggerone.........unless someone else knows better............
CC
:cool:
badge removal
CC,
I used fishing line as they are stuck on very well, the dental floss kept breaking you will actually be cutting through double sided foam not glue.The foam stuff on the back is an absolute b*****d to get off I used a wire brush drill attachment to get mine off and you can get replacment foam from halfords when you come put it back on.Andy
Re: badge removal
andy malton said:
CC,
Cheers Andy, I'll get some...........;)
CC
:cool:
spare badge
just as a matter of interest,
if anybody has a spare badge, or knows where i can get one....!
cheers,
d:gringo
Re: spare badge
cheers,
d:gringo
From my repair bill, they are quoted at £6.83 + VAT each. Part No 16112325183
Mike:)
