Remus/code plug again(sorry)
GEOFFREY DEACON
Leicestershire
Im sorry to bring this up again but flustered,.Remus titainiun,Y piece, K&N, and No code plug fitted ( ever?) But still running weaker than I like,. Can I do something more to richen or is Teclusion the next step. Could the tps be reset or another code plug etc, any info would be greatful.Geoff..:confused:
Hi Geoff, just been through the same dilema with y-piece and Remus titanium. Plugs were always looking a bit lean for my liking. Finally showed bike to a race tuner locally who reckoned that 2 years and the valves will have blown! Apparantly not such a problem on the continent as the climate is warmer and the "brain" can adjust sufficiently within the OE parameters to cope safely. He recommended replacing the original exhaust (which I've since done) or fitting a different chip. Techlusion may be your answer. I've now got a very cheap exhaust for sale!
Geoff, the only way you can richen it up is either a chip or a techlusion. TPS etc will have no effect. My prefered option is techlusion. It does work, but best of all it is easily adjustable for any set up. :)
OK Took the plunge and ordered the R259 techlusion, from TTS , Good peaple with lots of advice etc. Any good set-ups out there??.:thumb
Wooo! look at money bags!!!
Seriously Geoff. I'll see how you get on with the Techclusion, if it's ok I might splash out as well.
