As part of my plans to crash a bit better whilst enjoying our green and pleasant lanes I want to fit renthals as my standard bars are starting to resemble the slightly upwards pointing cow horns I had on the pushbikes of my youth....
I have trawled round the forums, spoken to a few people and have a whole bunch of good information. But a question or two still about tackling the dreaded heated grips with the wires in the bars.
I am fitting Renthal Twinwalls, bought off flea-bay for a song, £30 with cross brace.
I bought handlebar clamps / converters which also give a useful 1" raiser. They are: 01-1084 Pro Taper Clamps TAI-49 just £19.16 from MD Racing Products TEL: +44(0)1935 429646
Tobys tips on fitting Renthals to a 1200, chopping off the flange of the original bar weights and using rawlbolts with a 100mm countersunk caphead bolts all looks good. All these bits were a fiver! See http://www.ukgser.com/forums/showthread.php?t=51923
Earthmovers approach (link in above thread) was more complex, involving Helicoiling - but this might be the way to go. Again his was for the simpler 1200 with external wiring. Will have a strip down and check out options on Saturday.
All the above is a dodle to do. Then we have the b*stard heated grips to contend with.
Adopting Tobys approach I cant imagine how I can thread the wires in from the end, even at all (see below about reversing the heating elements).
Some things I have heard...
So, any comments on the above?
Does the alloy really dissipate heat to such an extent that its not worth doing anyway. I hope so in that I am lazy and mechanically inept, but I hope not as I commute 80m every day rain or shine on the beast.
Has anyone fitted Oxford Grips, do they go straight on? Thinking of the Sports ones. I'll bet their bar mounted control switch is for regular 22mm bars, not 28mm - probably easily fixed tho'.
Has anyone drilled Renthals and had a few offs, any comments on compromising strength (although it obviously will).
Are there other threads that specifically address all the above that I have missed?
Thanks for any help / comments / tips.
- Cant drill Renthals as it weakens them.
- Alloy (ie Renthals) dissipates heat away from grips.
- Rewind grip elements in reverse so wires feed into the inner face. See http://www.ukgser.com/forums/showthread.php?t=226268
- Just fit Oxford Heated grips and be done.
