Repair plug
NeilH
Great Haseley, Oxfordshire
What is the code for the repair plug that goes into part number 61347694306 (Axu power ports)?
Is it part number 83300402338?
And if someone can help me out with the link to the RT-P facebook page mentioned in the "2009 R1200RTP right hand switch gear" post I'd like to take a look.
Neil
Hi Neil,
Go on to facebook and copy/paste this into the search bar: BMW R1200RTP
I can't link you to the post as I'm not a member but join up and have a flick through it and I'm sure you'll find it.
And yes, the part number 83300402338 you give is most likely the right one. If I remember rightly, some early bikes had a slightly different power socket which would use 83300402343 as the repair plug though.
Will
Neil, do you mean repair plug? or just accessory plug such as these: https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=auxiliary+power+plug&search=SEARCH
I was looking for the repair plug which would come of the wiring loom into the back of the port......not the hella plug that plugs in.
Will - thanks for that....I tried R1200RT on facebook but didn't get much, changing to BMW R1200RT and I found the group.
Noted about the older models.....I think mine is later than the 83300402343 connection.
Will now try and source one in 2 weeks time when I'm back in the UK permanently (27th Nov 2019) - just in time to MOT the bike again.
