Replacement spot bulbs 2010 GSA
Oldrat
Much better now Posh Pete is on ignore
'arrow, near the 'ill.
As it says, I have a 2010 with OEM spots and am interested in changing the bulbs to match the colour of the HID headlamp, more white less yellow.
Anyone recommend any particular bulb (That doesn't upset the Can thing)
First of these aren't connected to the ZF unit like the headlight, they have their own replaceable fuses so you can do what you want.
Second, do you just want a colour match or do you want the light as well? If just the colour then go buy a pair of LED bulbs (no idea if they are H3 or H1) they will be bright, white and get you seen but wont put much light on the road. Shouldn't be a problem as you have a hid headlight and you will save power so save fuel. They are about a tenner. If you do want the extra light the as above, go get a pair of 35w hids.
gen bm led aux lamps easy to fit and the dogs danglies,bright white and good illumination:thumb
The easiest option for colour alone are the Blue Phillips lights available from various places- try Nippy Normans...
Hi guys, thanks to all of you for useful comments.
I don't need more light on the road the HID is sufficient.
I'm rather after being seen and so a colour match would suffice as long as it wasn't candle powered:eek
LED sounds good, any linkies :nenau and can anyone confirm the fitment so I could just order off t' interweb..
Lazy I know but I'm covered in plaster, I get more on me than the walls. and as far as the bike is concerned I only just get time to ride it lately, let alone farkle.:D
Thanks Wheel nut
Exactly what I'm loking for. A nice bright pure white LED to match my HID
