Replacing oil in the pre-load rear shock reservoir.
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
I fancy giving this a go having watched one video.
What available oil to use here in the U.K.?
The video I saw only topped up the reservoir having pushed down the plunger. Is that all that can be done?
There may be a better video on YouTube but as yet to find it.
02 R1150GSA.
Patria o Muerte
Patricia:
Why would you wish to do so?
Quoting the hoary old merkin saying: If it ain't broke, doin't fix it.
Hi guys
First of all oil change will not fix broken preload adjuster...
What may look like an easy job it's not! Without vacuum bleeding/filling the adjuster it's almost impossible to get all the air out.
That will reduce the range of adjustment.
If you still want to give it a go any hydraulic oil will be fine you can use any suspension oil or mineral hydraulic fluid LHM plus it will work just fine. Just.
To make things a bit more colourful this is the inside of the Ohlins 1150GS preload adjuster.
Sent from my SM-G960F using Tapatalk
